16 years agozero-time oscillation
I have an error message :Error:" Zero-time oscillation in node "|welch|aufsummierer:inst6|Add8~82" at time 0.65 ns. Check the design or vector source file for combinational loop". when i use a functi...
16 years ago --- Quote Start --- can anybody help me with this topic? --- Quote End --- It depend on what you want. If you want to keep the old ausgangX value, place your case block inside the clock loop, like Daixiwen said. If you just want to add another ausgangX to resultreal, without a memory function, you have to replace: --- Quote Start --- WHEN 0 => ausgang0 <= ausgang0 + resultreal;ausgang <= ausgang0; --- Quote End --- with WHEN 0 => ausgang <= ausgang0 + resultreal; for every line. Regards, Ton
