16 years agozero-time oscillation
I have an error message :Error:" Zero-time oscillation in node "|welch|aufsummierer:inst6|Add8~82" at time 0.65 ns. Check the design or vector source file for combinational loop". when i use a functi...
16 years agoKeep your case block inside the cloked part of the process, if you don't, you are creating an infinite look when you synthesize.
