11 years agozero-delay buffer PLL issue
Hi, I've recently started using Altera's PLLs for a Cyclone V project. I'm creating a PLL, with the IP Wizard, with zero-delay buffer (zdbfbclk) mode enabled. I want to use the zdbfbclk port to dr...
11 years agoHave a look at the altera iopll ip core user guide (http://www.altera.com/literature/ug/ug_altera_iopll.pdf). To quote from it:
--- Quote Start --- If you select the zero delay buffer mode, the PLL must feed an external clock output pin --- Quote End --- So yes, you must connect it up. Regards, Alex
