14 years agoYes No question (Using FPGA as a wire)
1-Can I use FPGA, just as a wire, to carry a bidirectional line like I2C SDA from one pin of the FPGA to the other pin of the FPGA. In the FPGA there will not be an i2c master or slave it will just r...
14 years ago --- Quote Start --- Yes, you can --- Quote End --- Unfortunately, I have to contradict. All existing physical level I2C repeaters or level converters are based on special hardware features, please review the respective datasheets. A similar function can't be implemented with regular FPGA IOs as far as I understand. A repeater on a logical protocol level would be possible, but not an easy design. P.S.: --- Quote Start --- Any kind of buffer has to know the data direction. --- Quote End --- That's exactly the point.
