XCVR_ANALOG_SETTINGS_PROTOCOL XAUI
- 5 years ago
Regarding to your inquiry on the DFE, as I understand it from the V-Series Transceiver PHY IP Core User Guide, the SV DFE is configured through registers in user mode but not QSF assignment. This could explain why you are not seeing DFE related parameters in the Fitter report. You may refer to "Transceiver Reconfiguration Controller DFE Registers" in the user guide for further details on how to configure the DFE registers.
As I understand it, you have some inquiries related to checking the PMA analog settings from the Fitter report. Yes, your understanding is correct. You can find out the settings from Fitter report. The section that you are showing seems to be valid section with the right information. Note that some of the information might be referring to internal settings apart from those described in the user guide.
Regarding your inquiry on the bw_half_6p5, just would like to check with you which specific device that you are using so that I could further check if it is an internal setting.
