12 years agoXAUI IP Core compilation problem
Hi, I am designing a state machine to send a UDP packet through XAUI. The packet will be divided into 72 bits and reach a XAUI PHY IP Core produced by Megafunction. So basically it is not so compl...
12 years agoThe negative pins should automatically be connected - providing you have constrained your design correctly. This includes specifying the relevant I/O standards for all the pins in the design. When you specify a differential I/O standard for a pin and assign a pin location (to the positive driver/receiver), Quartus will automatically assign the negative pin for you.
So, I suspect you've not specified a differential I/O standard for the pins you've listed.
