17 years agoWrong value from 7 segment display
Hello, I am a newbie here using Cyclone II FPGA starter dev board. I am trying to program (VHDL) the 7-segment displays on the FPGA starter board to display 4 digits value. Therefore the result is no...
17 years agoThe code is correct so far. You either should have copied pin location assignments from another Dev. Kits example design or entered it on your own. I can't know about.
As as result, th edesign should use the below location assignments. Can you verify them in the *.pin file?set_location_assignment PIN_J2 -to HEX0
set_location_assignment PIN_J1 -to HEX0
set_location_assignment PIN_H2 -to HEX0
set_location_assignment PIN_H1 -to HEX0
set_location_assignment PIN_F2 -to HEX0
set_location_assignment PIN_F1 -to HEX0
set_location_assignment PIN_E2 -to HEX0
set_location_assignment PIN_E1 -to HEX1
set_location_assignment PIN_H6 -to HEX1
set_location_assignment PIN_H5 -to HEX1
set_location_assignment PIN_H4 -to HEX1
set_location_assignment PIN_G3 -to HEX1
set_location_assignment PIN_D2 -to HEX1
set_location_assignment PIN_D1 -to HEX1
set_location_assignment PIN_G5 -to HEX2
set_location_assignment PIN_G6 -to HEX2
set_location_assignment PIN_C2 -to HEX2
set_location_assignment PIN_C1 -to HEX2
set_location_assignment PIN_E3 -to HEX2
set_location_assignment PIN_E4 -to HEX2
set_location_assignment PIN_D3 -to HEX2
set_location_assignment PIN_F4 -to HEX3
set_location_assignment PIN_D5 -to HEX3
set_location_assignment PIN_D6 -to HEX3
set_location_assignment PIN_J4 -to HEX3
set_location_assignment PIN_L8 -to HEX3
set_location_assignment PIN_F3 -to HEX3
set_location_assignment PIN_D4 -to HEX3
