11 years agowriting information into avalon slave in c
I have a NIOS II which is connected to a vga component with avalon memory mapped slave. In the VHDL entity, i have address, writedata, readdata, and chip select. the address base of the avalon memory mapped slave is 0x3008. I am not sure how to write information into the memory mapped slave. The address is used so i can write data into different signals. So far i have something like this in c: # define x (char *) 0x3008 main(){ while(1) *x=0x0F; // whatever values i need to pass. }2 Replies
From NIOS you just treat it as if it is any other bit of memory and the processor will take care of the signalling (hence they are called memory-mapped).
There are handy functions provided in the NIOS BSP that are useful when writing to slave devices such as: IOWR_32DIRECT(<base address>,<offset in bytes>,<32bit data>); IORD_32DIRECT(<base address>,<offset in bytes>); And similar ones for 8bit and 16 bit data. Alternative you can do something like: int main(){ char* x = 0x3008; *x = 0x0F; } - Altera_Forum
--- Quote Start --- From NIOS you just treat it as if it is any other bit of memory and the processor will take care of the signalling (hence they are called memory-mapped). There are handy functions provided in the NIOS BSP that are useful when writing to slave devices such as: IOWR_32DIRECT(<base address>,<offset in bytes>,<32bit data>); IORD_32DIRECT(<base address>,<offset in bytes>); And similar ones for 8bit and 16 bit data. Alternative you can do something like: int main(){ char* x = 0x3008; *x = 0x0F; } --- Quote End --- Thanks i got it working. Another question i have has regards to the altera monitor program. Has anyone used it? I'm trying to use the sleep function included from the unistd.h. However when i compile it tells me there is an undefined reference to sleep(). any ideas? ps. usleep() gives the same error
