17 years agowrite code for schematic diagram
hi! I HAVE A cmos JK 807A CAMERA: number of pixel: 628(h)x582(v)<PAL>, Resolution:380 lines. scaning frequency:50 Hz min.lllumination: 0.2~3 Lux S/N ratio : 40db white balance : Auto...
17 years agoFrom your camera specs I assume that you have a composite video output camera. So you should best use an FPGA board with a video codec on board. The de2 board (http://de2.terasic.com)is an excellent platform for your project. The board also has worked out examples using such a camera. You should of course update the provided designs for your project.
--- Quote Start --- hi! i make a block schematic for my work.can u write vhdl code for the block schematic.also tell me is it possible with that camera or not.Can You help me!!!!! --- Quote End --- The relation of your composite video camera with the (incomplete) block diagram that you have drawn is unclear.
