18 years ago
will Cyclone III work with unconected VCCA PLL ??
I actually made e board already and didn't connected thous VCCA PLL pins and now my board don't work (I can't program it and software all time is saying "can't access JTAG chain"
is that because of unconnected VCCA pins ?
here is my DIY cyclone III board and I can't get it to work :(
I have pull-up 10K ohm on CONF_DONE and nStatus + other Jtag pins are also conected like in Cyslone III handbook Figure 10–23. schematic.
for programming I use self soldered Byteblaster II, programmer works correctly because I can program my old cyclone II board.
https://www.alteraforum.com/forum/attachment.php?attachmentid=318
    I made today some tests and found strange PLL behavior it outputs strange frequency in place of 16Mhz I get 22,7Khz frequency I set PLL to ratio 1/1 so it need to be 16Mhz, I tested it by making such test code where i created 2 clocks one direct 16Mhz clock input I routed to Global clock line and other was PLL clock and for testing I created logic 6bit(/128) frequency divider.
    and as I have only 1Msps oscilloscope I saw that output of non PLL clock logic was 128Khz and it is correct, value for 16Mhz clock, but PLL clock I measured directly and it was 22,7Khz :(
    Why PLL don't work correctly ??
    LIBRARY ieee;
    USE ieee.std_logic_1164.all;
    use IEEE.STD_LOGIC_ARITH.ALL;
    use IEEE.STD_LOGIC_UNSIGNED.ALL;
    --  Entity Declaration
    ENTITY Cyclone_III_pin_test IS
    	-- {{ALTERA_IO_BEGIN}} DO NOT REMOVE THIS LINE!
    	PORT
    		A : Out STD_LOGIC_vector(7 downto 0);
    		Clk : IN STD_LOGIC
    	-- {{ALTERA_IO_END}} DO NOT REMOVE THIS LINE!
    END Cyclone_III_pin_test;
    Architecture Cyclone_test of Cyclone_III_pin_test is
    signal CLK_1ms,B,B2,C,D: std_Logic;
    signal Q,Q2 : STD_logic_vector (5 downto 0);
    component C3PLL_test
    	PORT
    		inclk0		: IN STD_LOGIC  := '0';
    		c0		: OUT STD_LOGIC ;
    		locked		: OUT STD_LOGIC
    end component;
    component clk_route
    	PORT
    		inclk		: IN STD_LOGIC ;
    		outclk		: OUT STD_LOGIC
    end component;
    begin
    clk_16M : clk_route
    Port map( inclk=>clk,outclk=>C);
    CLock_PLL : C3PLL_test
    Port map( inclk0=>clk,c0=>CLK_1ms);
    --CLK_1ms<= CLK;
    A(3) <= CLK_1ms;
    A(2) <= CLK;
    A(1) <= C;
    A(0) <= CLK_1ms;
    A(4)<= D;
    process(clk_1ms)
    begin
    --if clk_1ms ='1' then
    	if rising_edge(clk_1ms) then
    	Q<=Q+1;
    		if Q ="000000" then
    			if B='1' then
    			A(7 downto 5)<= "111";
    			B<='0';
    			else A(7 downto 5)<= "000"; B<='1';
    end if;
    end if;
    end if;
    end process;
    process(c)
    begin
    	if rising_edge(c) then
    	Q2<=Q2+1;
    		if Q2 ="000000" then
    			if B2='1' then
    			D<= '1';
    			B2<='0';
    			else D<='0'; B2<='1';
    end if;
    end if;
    end if;
    end process;
    end Cyclone_test;
    I just found out why PLL is working improperly and instead of 16Mhz give out 22Khz its because I also forgot to connect VCCD1;2 pins to 1,2V core voltage.
    I will have to correct that mistake, and then PLL must work properly.
    Cool PCB design
    I guess PLL power diff from Cyclone2 may solve some power issue in Cyclone3. So they div VCC to 2 or more.
