18 years agowill Cyclone III work with unconected VCCA PLL ??
I actually made e board already and didn't connected thous VCCA PLL pins and now my board don't work (I can't program it and software all time is saying "can't access JTAG chain" is that because...
18 years agoI made today some tests and found strange PLL behavior it outputs strange frequency in place of 16Mhz I get 22,7Khz frequency I set PLL to ratio 1/1 so it need to be 16Mhz, I tested it by making such test code where i created 2 clocks one direct 16Mhz clock input I routed to Global clock line and other was PLL clock and for testing I created logic 6bit(/128) frequency divider.
and as I have only 1Msps oscilloscope I saw that output of non PLL clock logic was 128Khz and it is correct, value for 16Mhz clock, but PLL clock I measured directly and it was 22,7Khz :( Why PLL don't work correctly ??LIBRARY ieee;
USE ieee.std_logic_1164.all;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Entity Declaration
ENTITY Cyclone_III_pin_test IS
-- {{ALTERA_IO_BEGIN}} DO NOT REMOVE THIS LINE!
PORT
A : Out STD_LOGIC_vector(7 downto 0);
Clk : IN STD_LOGIC
-- {{ALTERA_IO_END}} DO NOT REMOVE THIS LINE!
END Cyclone_III_pin_test;
Architecture Cyclone_test of Cyclone_III_pin_test is
signal CLK_1ms,B,B2,C,D: std_Logic;
signal Q,Q2 : STD_logic_vector (5 downto 0);
component C3PLL_test
PORT
inclk0 : IN STD_LOGIC := '0';
c0 : OUT STD_LOGIC ;
locked : OUT STD_LOGIC
end component;
component clk_route
PORT
inclk : IN STD_LOGIC ;
outclk : OUT STD_LOGIC
end component;
begin
clk_16M : clk_route
Port map( inclk=>clk,outclk=>C);
CLock_PLL : C3PLL_test
Port map( inclk0=>clk,c0=>CLK_1ms);
--CLK_1ms<= CLK;
A(3) <= CLK_1ms;
A(2) <= CLK;
A(1) <= C;
A(0) <= CLK_1ms;
A(4)<= D;
process(clk_1ms)
begin
--if clk_1ms ='1' then
if rising_edge(clk_1ms) then
Q<=Q+1;
if Q ="000000" then
if B='1' then
A(7 downto 5)<= "111";
B<='0';
else A(7 downto 5)<= "000"; B<='1';
end if;
end if;
end if;
end process;
process(c)
begin
if rising_edge(c) then
Q2<=Q2+1;
if Q2 ="000000" then
if B2='1' then
D<= '1';
B2<='0';
else D<='0'; B2<='1';
end if;
end if;
end if;
end process;
end Cyclone_test;
