8 years agoWhy should I learn Qsys/Platform Designer
I've created digital designs for 5+ years. I have never used Qsys. I've written HDL modules, manually wired them, did timing analysis and eventually synthesize them. I never found the need to use Qsy...
8 years agoif you think you are fine with it, that should be fine.
but I ( and many people ) recommend to use Qsys at least once. then, if you think it is meaningless for you , you don't have to use it anymore.
