8 years agoWhy should I learn Qsys/Platform Designer
I've created digital designs for 5+ years. I have never used Qsys. I've written HDL modules, manually wired them, did timing analysis and eventually synthesize them. I never found the need to use Qsy...
8 years agoIf you want to design with lots of Altera IP modules, and just have them wired together, with a bit of your logic, then Qsys/PlatformDesigner is a reasonable way to go.
However (as I do) you tend to use very little (if any) of the canned Altera IP modules, then Qsys/PD is basically irrelevant and provides no real added value. So it depends on what you are trying to do, and how you plan to do it.
