17 years agoWhy is the speed of operations not constant? Is the cache the reason?
Hi First of all I'm using Quartus 8.1 and the NiosII IDE 8.1. The Nios II system I set up, processes data from an ADC with the help of a FFT module I added to the processor system. The...
17 years agoIf your system runs at 100MHz, then you will have a clock cycle of 10ns.
you say that the 1. & 2. and 4th take 20ns = 2 clocks for all 512 iterations but the 3. takes 100ns = 10 cycles for all 512 loop steps. if some interrupt or refresh cycle or whatsoever occcurs then you would measure this additional time within all 4 loops and not only in loop 3. this is indeed strange have you setup signaltap and monitored what is giong on on each of the 4 loop cycles ? especially those custum instructions. another question you wrote Real_f32 = CI_INTTOFLOAT(Real_s16); Imag_f32 = CI_INTTOFLOAT(Imag_s16); Result1_f32a[SampleCounter_u16] = CI_FPSQRT(Real_f32*Real_f32 + Imag_f32*Imag_f32)/STEP_SIZE_1MILIG; so you have 2 float multiplikation and one float addition why don't you write Result1_f32a[SampleCounter_u16] = CI_FPSQRT( CI_INTTOFLOAT( Real_s16 * Real_s16 + Imag_s16 * Imag_s16 ) )/STEP_SIZE_1MILIG; now you have 4 integer multiplikation and one integer addition, this should be a bit faster as also only one CI_INTTOFLOAT operation is needed.
