SFærø
8 years agoWhy doesn't my DE2-115 Altera FPGA board want to be programmed? (keeps getting failed when i try programming to USB-blaster)
I was creating software in Eclipse for my FPGA board, which I had programmed with VHDL and Qsys to make an embedded computer system. I was using my oscilloscope to measure my EX_IO pins, since I was ...
SAR
8 years ago[QUOTE]In short, the boards USB-blaster programming function all of a sudden stopped working, the board won't talk with the computer at all, and it won't reset to the usual crazy blinking like it always does when the board is turned off and on again.[/QUOTE]
"Do you mean auto detect is not working" & "factory default image is not loaded"
May some IC would have damaged or power issues.
- Check if any power or ground are shorted
- Check FT245 OR MAX II IC and its power.
- Check all the components on power path(Capacitors and converter).
