13 years agoWhy does quartus think my signal is a clock?
Here is the code snipped begin
write_register <= '1' when ((chipselect = '1') and (write = '1') and (byteenable = "1111") ) else '0';
process (clk,reset_n)
begin -- process
if reset_n...
13 years agoI changed the code to this but the problem persists
begin -- process
if reset_n = '0' then
out_settings <= x"FEDCBA9876543210";
elsif rising_edge(clk) then
enable <= '0';
if (write_register = '1') then
case address is
when '0' =>
out_settings(31 downto 0) <= writedata;
when '1' =>
out_settings(63 downto 32) <= writedata;
enable <= '1';
when others =>
enable <= '0';
end case;
end if;
end if;
end process;
process (enable,out_settings) is
begin
if enable = '1' then
for i in 0 to (N_CHANNELS_ANA - 1) loop
for j in 0 to 3 loop
out_register(i)(j) <= out_settings(i*4 + j);
end loop;
end loop;
end if;
end process;
process (ana_bits_in, out_register)
variable index : integer range 0 to (N_CHANNELS_ANA - 1);
begin
index := conv_integer(out_register (i)(3 downto 0));
ana_bits_out(i) <= ana_bits_in(index);
end loop;
end process;
