13 years agoWhy does quartus think my signal is a clock?
Here is the code snipped begin
write_register <= '1' when ((chipselect = '1') and (write = '1') and (byteenable = "1111") ) else '0';
process (clk,reset_n)
begin -- process
if reset_n...
13 years agoIn the second process you write:
out_register <= out_register out_register behaves like a latch, so you need a latch enable. May be Quartus takes "enable" as a clock because the register refresh it's output when enables goes high. I think Quartus inferred a latch.
