MinzhiWang
2 years agoWhy do i get this error when I use lvds?
Hello guys, My device is 10CX220YF780E5G and the Quartus is QPP23.4. I implemented one channel LVDS receiver in my project. External PLL was checked. After full complilation, I found LVDS module was...
- 1 year ago
Yes, I found it in Volume 2, pages 4-18, from the link I provided earlier.
Let me know if you can't find it.
Aqid
AqidAyman_Altera
1 year agoI also agree differential termination should be used, but it is up to you to figure out what is stable for your system. If you don’t use on-chip termination and it is working okay on this board, I can understand you may have concern for building a larger volume of boards and it continuing to be stable. It “should” work with on-chip differential termination.
Technically, the general purpose I/O pins do not support CML, that is typically a standard used with the transceivers with AC coupling.
