Why do i get this error when I use lvds?
- 1 year ago
Yes, I found it in Volume 2, pages 4-18, from the link I provided earlier.
Let me know if you can't find it.
Aqid
What is the significance of the blue trace in the scope shot?
Although we agree the Vid min is satisfied, we can’t tell the common mode voltage of the differential signal. It must also be in the supported common mode range of the Cyclone 10 GX LVDS receiver. There is mention of Voh on the CML datasheet indicating it is near VCC which is either 2.5V or 3.3V, so this is above our common mode range.
- MinzhiWang1 year ago
1. The bottom blue line signal is just of the oscilloscope's reference to trace the object pulse.
2. You're right, I check the hardware again. The connection between OR gate's CML output and FPGA lvds receiver input under AC coupling. In this case, we still have above issue. That's we can't enable the on-chip termination.
Do we nned other extra outside pull-up and/or pull-down resistors?
