Why device has stopped receiving configuration data when programming?
Could you confirm if you are providing the refclk to the PCIe IP on your board?
You may refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/agilex/ug-ag-config.pdf Chapter 7 on how to further debug the issue.
Here is the device I use: AGIB027R29A1E2VR0
And I am using these pins for ref clock:
For EP side:
refclk_pcie_14c_ch1_p(n) : CR70 : input : Current Mode Logic (CML) : 0V : 14C
refclk_pcie_14c_ch1_p : CU68 : input : Current Mode Logic (CML) : 0V : 14C
refclk_pcie_14c_ch0_p(n) : DM70 : input : Current Mode Logic (CML) : 0V : 14C
refclk_pcie_14c_ch0_p : DR68 : input : Current Mode Logic (CML) : 0V : 14C
For RP side:
refclk_pcie_rp_ch0_p(n) : FV26 : input : Current Mode Logic (CML) : 0V : 15A
refclk_pcie_rp_ch0_p : GA27 : input : Current Mode Logic (CML) : 0V : 15A
refclk_pcie_rp_ch1_p : GY26 : input : Current Mode Logic (CML) : 0V : 15A
refclk_pcie_rp_ch1_p(n) : HC27 : input : Current Mode Logic (CML) : 0V : 15A
Anything incorrect with my assignment?
