17 years ago
Why can't I do simuation?
When I tried to do simulation, a window popped out with the error:
"No simulation input file assignment specified on Simulator page of the Settings Dialog box".
I checked the '"Assignments->Settings", I found I included my vwf file into the project. Then, why can't I do simulation?....
Your advice and help are highly appreciated!
    --- Quote Start ---
    No, that's for creating an output file to do simulations in a 3rd party tool. In the Assignments -> Settings box, along the left side where you see things like Files and EDA Tool Settings, there should be one called Simulator Settings, and you add the file there.
    --- Quote End ---
    This doesn't work for my version Modelsim version 6.5b (has to use this version to simulate legacy AHDL code).
    I have several screen dump files in PNG-format that illustrates the issue, however this site doesn't accept png-format files. :(
    Hope to hear from you soon.
    I want to execute D_FF like this into DE1 kit, but I do not know to use clock pin, reset for KIT. Please, help me
    library ieee;
    use ieee.std_logic_1164.all;
    entity d_ff is
    port(
    clock: in std_logic;
    d: in std_logic;
    q: out std_logic
    end d_ff;
    architecture arch_dff of d_ff is
    begin
    process(clock)
    begin
    if (clock'event and clock='1') then
    q <= d;
    end if;
    end process;
    end arch_dff;
    --- Quote Start ---
    --- Quote End ---
    I get into the same problenm:(:(
    Thank for reply.
    Do yo mean I should go to "Assignments->Settings->EDA Tool Settings->Simulation?
    Assignments -> Settings -> Simulation and add the file there...
