Why "1.5V IO standard" output pin with 50ohm load not 1.5V when Termination is set to OFF
Hello JJ,
I would like to get some clarification from you first.
What is the FPGA device that you use?
What is the difference between DC1M and DC50?
Aqid
- FvM2 years ago
50 ohm load termination (oscilloscope setting "DC50") creates essentially a voltage divider between source and load impedance. In case of 50 ohm source termination, you get about 50% output level.
67 % output level (1.0/1.5) indicates 25 ohm output impedance, sounds plausible for higher drive strength setting. Expected 1.5 V would be achieved with zero output impedance which isn't feasible.- jkhoo2 years ago
Hi FvM,
Yes, your explanation make sense. The current drive strength i am using is 12mA, which is at the high end of the setting.
Hi Aqid,
I am using Stratix V : 5SGXMA3K3F40C4.
DC1M = 1Mohm load and DC50 = 50 ohm.
Where in stratix V spec that state down that with output pin termination set to off, the impedance of the output port is depend on the current strength setting and is there a table in the spec listing down what is the impedance/termination for the output port relative to the current strength (2mA to 12mA) for 1.5V IO standard and other standard?
- jkhoo2 years ago
Hi Aqid,
Appreciated if you can help me out on the question i have above.
Regards, JJ
