14 years agoWhich QSF file is used in Quartus ?
In Quartus, with Assignment Editor, I can manage the pin locations, and I see, with the date, that my file project.qsf in my project folder is updated. Despite this, during the compilation, I have...
14 years agoThank you for your answers.
You're right, the simple is case is when there's no revision. BUT I have a revision (B). So I have in my project folder two files project.qsf and project_b.qsf. I suppose, depending of the revision, only ONE file should be read, but I saw, that, in some case, the second qsf file is used, for the first revision. When is it possible ? To avoid any confusion, I'm trying to avoid revision, and to have separate projects. I won't use revision anymore. For the moment it works, thank you again. Arnaud.
