19 years agowhich is the best choice for H.264
Hello every master. which is the best choice for H.264? should i use stratix gx or stratix II? in the altera web i find the ip core which made by Ateme,and they use stratix II. so I want to ...
19 years agoStratix II is probably fine for it. You would only need a GX part if you need to use high speed serial I/O. Also H.264 is a beefy algorithm so the more size the better (and the fmax increase will help too).
For H.264 look for the amount of onchip memory and multiplier blocks that are available. Those are typically what you look for in a FPGA when implementing DSP capabilities.
