16 years agowhere do I find altera_mf library?
I made a 25MHz clock using the Mega wizard of quartus, and put the PLL in my Active HDL design (I don't think the problem is with the Active HDL, though), and when compiling I get this error regarding the ALtera_mf library which isn't in my design. Where do I find the Altera_mf library? thanks, Roy2 Replies
altera\quartus\eda\sim_lib
you can see it here. - Altera_Forum
You should read the Quartus II handbook section on simulation with EDA tools:
http://www.altera.com/literature/hb/qts/qts_qii5v3_01.pdf And have a look here: http://quartushelp.altera.com/10.0/master.htm#mergedprojects/eda/quartus2/eda_ref_presynth_lib.htm Basically the simulation libraries are always located at C:\altera\<version>\quartus\eda\sim_lib Jake
