JET60200's avatar
JET60200
6 years ago
where can find the user guide of "Avalon-MM Clock Crossing Bridge IP" in Quartus 19.2 ?
I check customer PCIE AVMM DMA design , and find an "Avalon-MM Clock Crossing Bridge" module inside. BUt from PLatform Designer, I don't find the IP 's user guide ?
Where can I find ?
  • Hi @ShyanYewT_Intel​ ,
    Inside Quartus Standard Edition 18.1, I wanto create a proect example , and instantiate an "Avalon-MM Clock Crossing Bridge IP" in IP Catalog,
    But I don't find where can I ADD IP of "avmm clock cross bridge"? Can you give some advice ?
    • RichardT_altera's avatar
      RichardT_altera
      You can only find it in the IP catalog of platform designer. Go to Tools > Platform Designer.
  • Bridges are used to control the topology of a Qsys system. The Avalon-MM Clock Crossing Bridge transfers Avalon-MM commands and responses between different clock domains. You can also use the Avalon-MM Clock Crossing Bridge to bridge between AXI masters and slaves of different clock domains. You can refer to the link below for more information.
    Reference: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qps-platform-designer.pdf#page=212
    p.s. Don’t forget to Reply, and Select the Best Answer. :)
