where can find the user guide of "Avalon-MM Clock Crossing Bridge IP" in Quartus 19.2 ?
- 6 years ago
Bridges are used to control the topology of a Qsys system. The Avalon-MM Clock Crossing Bridge transfers Avalon-MM commands and responses between different clock domains. You can also use the Avalon-MM Clock Crossing Bridge to bridge between AXI masters and slaves of different clock domains. You can refer to the link below for more information.
p.s. Don’t forget to Reply, and Select the Best Answer. :)
Hi @ShyanYewT_Intel ,
Inside Quartus Standard Edition 18.1, I wanto create a proect example , and instantiate an "Avalon-MM Clock Crossing Bridge IP" in IP Catalog,
But I don't find where can I ADD IP of "avmm clock cross bridge"? Can you give some advice ?
You can only find it in the IP catalog of platform designer. Go to Tools > Platform Designer.
