When to reset RSU block?
- 5 years ago
You should observed that the reconfiguration trigger condition value is "nconfig_source".
1. So is it recommended to reset the RSU core each time entering into the factory image?
This is only needed during power up. There will be no issue on always resetting on every factory image load.
3. Will all the information in the "control \ status \ update" registers lost after power on or RSU block reset?
The status register will not be reset when you assert reset on the remote update IP. It will only reset the state machine of the remote update IP.
- RobertLiang5 years ago
Thank you!
I guess that because the FPGA is volatile, the previous application information will not be available after a new power cycle.
Therefore can I judge if it's the first time that the factory image load after power on, by reading the previous status registers to see whether the contents are all default value?
