16 years agowhen simulating with modelsim,the question appears!
hello! when I use modelsim over quartus II to simulation , sometimes It failed by RTL level simulation and successed by gate level simulation simultaneously. maybe the reason is t...
16 years agoHI,
thepancake, thanks for your reply. I have a try according to your method. I delete these signals(altera_reserved_tdo, altera_reserved_tdi, altera_reserved_tck, altera_reserved_tms).Luckly,the RTL level simulation is passed. but there is no data in the wave window. and the message is below:# ** Error: (vsim-7) Failed to open VHDL file "DATA_ROM.mif" in rb mode.# No such file or directory. (errno = ENOENT) In this situation, I tried to use gate level simulation again, to my surprise, The simulation also failed.and the error message is below:# ** Error: (vsim-3817) Formal port "altera_reserved_tms" declared in the entity is not in the component.# Time: 0 ps Iteration: 0 Region: /sin_gnt_vhd_tst/i1 File: SIN_GNT.vho# ** Error: (vsim-3817) Formal port "altera_reserved_tck" declared in the entity is not in the component.# Time: 0 ps Iteration: 0 Region: /sin_gnt_vhd_tst/i1 File: SIN_GNT.vho# ** Error: (vsim-3817) Formal port "altera_reserved_tdi" declared in the entity is not in the component.# Time: 0 ps Iteration: 0 Region: /sin_gnt_vhd_tst/i1 File: SIN_GNT.vho So what i should do next step?
