16 years agowhen simulating with modelsim,the question appears!
hello! when I use modelsim over quartus II to simulation , sometimes It failed by RTL level simulation and successed by gate level simulation simultaneously. maybe the reason is t...
16 years agoTricky,
Thanks for your reply. My english is not well,and i am new to modelsim. The first question: when i use modelsim to simulation over quartus II,It faild by RTL level simulation. the error message is below:# ** Error: (vsim-3732) E:/SIN_GNT/simulation/modelsim/SIN_GNT.vht(60): No default binding for component at 'i1'.# (Port 'altera_reserved_tdo' is not on the entity.)# Region: /sin_gnt_vhd_tst/i1# ** Error: (vsim-3732) E:/SIN_GNT/simulation/modelsim/SIN_GNT.vht(60): No default binding for component at 'i1'.# (Port 'altera_reserved_tdi' is not on the entity.)# Region: /sin_gnt_vhd_tst/i1# ** Error: (vsim-3732) E:/SIN_GNT/simulation/modelsim/SIN_GNT.vht(60): No default binding for component at 'i1'.# (Port 'altera_reserved_tck' is not on the entity.)# Region: /sin_gnt_vhd_tst/i1# ** Error: (vsim-3732) E:/SIN_GNT/simulation/modelsim/SIN_GNT.vht(60): No default binding for component at 'i1'.# (Port 'altera_reserved_tms' is not on the entity.)# Region: /sin_gnt_vhd_tst/i1# Loading rtl_work.data_rom(syn)# Error loading design but it successed by Gate level simulation.I can't understand the reason . For the other question: I usually drag/drop the intermidiate signals from the path(workspace->i1) to the wave window.but sometimes i can get the right answer and sometimes not. can you explain is in detail?
