rshal2
7 years agoWhen do we need to customize preloader?
Hello, The general scheme of building preloader is composed of: handoff -> preloader config + u-boot-spl source code -> binary So it is usually "automatic" build without any customization. Yet, ...
- 7 years ago
Hi ranran,
Here is an example; for enabling HPS-to-FPGA Bridges from the preloader, the preloader will check the status of the FPGA then automatically enables bridges that are configured in Qsys/platform designer (Standard) and the BSP if the FPGA is configured.
For more information, I reckon you refer to GSRD v13.1 - Programming FPGA from HPS.
Regards.
EBERLAZARE_I_Intel
7 years agoHi,
If you decide to have some hardware changes in your design for example, then you will need to customize your preloader to include the hardware.
To enable bridges you can refer here page 10.
Regards.
- rshal27 years ago
I try to ask if enabling the bridge is done as part of generating the preload file, or does it require manually modifying the file before compilation ?
Thank you very much,
ranran
