13 years agoWhat's the syntax that defines the path of a generated entity in Quartus .qsf file?
In a .qsf file, I'm trying to set TERMINATION_CONTROL_BLOCK via set_instance_assignment -name TERMINATION_CONTROL_BLOCK "e1:i1|e2:i2|e3:i3|s" -to o_pin[0] -tag __p0 This approach works as long as there is no VHDL generate statement in the hierarchy path. However, if I add a generate statement around an entity, ie: conditional_gen: if condition generate i2: component e2 ... ... end generate conditional_gen; Then the Quartus fitter no longer recognize the qsf file's TERMINATION_CONTROL_BLOCK assignment. What's the proper syntax for generated entity? Thanks5 Replies
--- Quote Start --- But I work out the problem. The single slash shown in the design hierarchy corresponds to double slash in the setting file, because the first one is treated as an escape. --- Quote End --- Glad to hear you figured it out. Cheers, Dave - Altera_Forum
I made a reply but it looks like it's not showing up at the moment because it triggered the forum software, somehow (post requires moderator approval?). But I work out the problem. The single slash shown in the design hierarchy corresponds to double slash in the setting file, because the first one is treated as an escape. Cheers, - Altera_Forum
--- Quote Start --- Look in the Quartus hierarchy display window. I just looked at a design that uses a generate statement (called g1) and its got a "\g1" in the path name. Cheers, Dave --- Quote End --- Hi Dave, Thanks for the suggestion. I gave it a shot but it doesn't seem to work. Quartus 12.1B177 Hierarchy shows: Top_Level|entity1_name:inst1_name|entity_name2:\gen_name:inst_name2 Here are the variations that I have attempted in the .qsf file: Top_Level|entity1_name:inst1_name|entity_name2:\gen_name:inst_name2 Top_Level|entity1_name:inst1_name|entity_name2:gen_name:inst_name2 Top_Level|entity1_name:inst1_name|entity_name2:\\gen_name:inst_name2 Top_Level|entity1_name:inst1_name|\gen_name:inst_name2 Top_Level|entity1_name:inst1_name|gen_name:inst_name2 Top_Level|entity1_name:inst1_name|\\gen_name:inst_name2 What I find curious is that for the "entity_name2:\gen_name:inst_name2" attempt, the output shows the error "entity_name2:gen_name:inst_name2" is not found (the slash is gone). Sure enough, if I open up the .qsf file, something removed the slash and re-saved the file. If Quartus found something in the setting file that it does not like, would it automatically update the setting? Here is the line that I'm having trouble with set_instance_assignment -name TERMINATION_CONTROL_BLOCK "entity_name1:inst_name1|entity_name2:\gen_name:inst_name|altera_mem_if_oct_stratixvct0|sd1a_0" -to QDRIIC_Q[2] -tag __QDRII_SLAVE_p0 Thanks - Altera_Forum
I'm trying to post a reply but the forum software incorrectly identify links within my post. Need to spam a few posts to reach count of 5
Cheers, Dave
