8 years agoWhat should I do if I see this message in the Qsys parameter message?
What should I do if I see this message in the Qsys parameter message? Is it a support issue? https://alteraforum.com/forum/attachment.php?attachmentid=15677&stc=1 <Error Message > I...
8 years agoHi. Looks like it doesn't like the 64 bit wide DMA setting. Is 64 bit allowed and compatible with the other blocks? Can you try setting DMA to 32 bit?
