10 years agoWhat is wrong with my Cyclone II configuration circuit?
I just got my Cyclone II PCB back from fab and assembled it. Everything is working correctly except the ASP configuration. My circuit seems to match everything I've found online, including the hand...
10 years agoHello
you can not download .sof file into eeprom. as Galfonz says, you need to convert your sof-file but into jic file. pof file is the file downloading into EEPROM directory. but your circuit does not seem it has the socket for writing eeprom. so, in this case you need create jic(JTAG Indirect Configuration File) file. this file is downloading file (to eeprom) via JTAG. since I don't have time to write detail. I give you a hint. see attached file. see you.
