9 years agoWhat is VHDL equivalent for Verilog $readmemb to initilze RAM/ROM?
The $readmemb() is mentioned in "Recommended Coding Styles" page 12-26. It seems that this can be used in simulation AND synthesis. If one unfortunately uses VHDL rather than Verilog, than how...
9 years agoUnfortunately, Altera has decided not to support what would be the most obvious replacement - the textio package (Xilinx Supports it).
That means the only ways to support mem init in synthesis are: 1. Use a constant and initialise the ram signal in the code: signal my_ram_sig : my_ram_type := MEM_INIT_CONSTANT; 2. Use a mem init function:
function mem_init_function return ram_t is
variable ret : ram_t;
begin
for i in ret'range loop
ret(i) := --some calculated value!
end loop;
return ret;
end function;
signal my_ram_sig : my_ram_type := mem_init_function;
3. Use attributes as an init to the ram (either in code or via project assignments)
type mem_t is array(0 to 255) of unsigned(7 downto 0);
signal ram : mem_t;
attribute ram_init_file : string;
attribute ram_init_file of ram :
signal is "my_init_file.mif";
The only issue with 3. is that it wont initialise in simulation. For simulation of method three, you could write a function to read the mif file to init the contents.
