12 years agoWhat is Timing between nCEO and DCLK in a multi-device AS Configuration ?
Is there timing requirements between nCEO and DCLK when configuring two FPGA's from one EPCS device? The master device (the first FPGA configured) operates in an AS configuration mode and once ...
12 years ago --- Quote Start --- Clarifications: The 3rd Board was previously not available to test this FPGA configuration issue with because of a bad power regulator. The regulator was fixed and I am able to power the board and attempt to program the FPGA's on it. If it did not have the problems the other boards had I would have replaced the FPGA's on the first two boards. --- Quote End --- Ok, I see. Its still not clear from this brief discussion what works and what does not. If you can program the FPGAs via JTAG, then that would indicate the issue is related to EPCS configuration. If some boards work and others do not, then it implies either a timing or waveform (signal integrity) issue. --- Quote Start --- I am about to concede to trying to configure the FPGA's from something other than the EPCS with pof's. I have an alternate set of DATA0, DCLK, nCE, etc. signals routed from another (well behaved) FPGA on the board. So I concatenate my two *.rbf's and clock these bytes in serially. So do you have a reference for the details of doing this ? Is the serial stream MSB first ? Do I need to do any byte swapping things? --- Quote End --- The Handbook for the device has pretty good details on what is required. PS data is serialized LSB-to-MSB. This doc has some notes: http://www.ovro.caltech.edu/~dwh/carma_board/fpga_configuration.pdf Cheers, Dave
