12 years agoWhat is the suitable Voltage level for clock input? Vccio , Vccd_pll ?
I'm designing board with cyclone IV, so i was checking several reference designs, and I looked in the Cyclone III LS FPGA, in this design the designer set the bank 7 and bank 8 with a Vccio=1.8 (the ...
12 years ago --- Quote Start --- Note however that "Table 1–2. Maximum Allowed Overshoot During Transitions over a 10-Year Time Frame for Cyclone IV Devices" on p449 implies that the I/O pins are actually 4.2V tolerant (100% duty cycle), so if you did drive the pin with 2.5V, it should not cause damage. Personally, I prefer to be conservative and would stay within the logic level limits imposed in Table 1–15. Texas Instruments and Fairchild have lots of dual-supply buffers that make it easy to interface 2.5V or 3.3V signals into a 1.8V FPGA bank. --- Quote End --- Instead of maximum ratings and allowed overshoot, we would primary refer to Table 1–3. recommended operating conditions for cyclone iv e devices , which specifies 3.6 V maximum input voltage independent of VCCIO. It should be also noted that previous FPGA families, e.g. Cyclone II had been advertised with a MultiVolt-I/O feature, allowing e.g. to feed 3.3V input level to a 1.5V bank. It's not completely clear what motivates the Vih,max specifications in table 1-15. Interestingly, the Cyclone V datasheet releases Vih,max for the 2.5V IO-standard to 3.6V again. Does this involve a hardware change? I guess it's just arbitrary.
