zlan01
6 years agowhat is the standard mode to reset the max10?
I can not find INIT_DONE, only find CONF_DONE, the previous reset mode using INIT_DONE for cyclone can not be used , will you please tell me the standard mode to reset the max10?
NurAiman_M_Intel
6 years agoHi,
- You can perform reset by using PLL or reset IP.
- You can also write RTL to perform reset internally when there is some problem
or you can connect the reset input to a switch
depends on your design.
Thank you.
Aiman
