zlan01
6 years agowhat is the standard mode to reset the max10?
I can not find INIT_DONE, only find CONF_DONE, the previous reset mode using INIT_DONE for cyclone can not be used , will you please tell me the standard mode to reset the max10?
zlan01
6 years agothanks a lot for you help,
after powering on, the fpga will:
- be configured by the configuring file
- after being configured , reset the whole register,
- go to implement the function
the content you mentioned above is the work in phase 1 , and what I care about is in phase 2 above,
- firstly can I use locked of the pll to reset the register of the fpga as below:
assign reset = locked ?
2. secondly , or should I construct a Resistance capacitance charging circuit to get the reset signal , and then input the reset signal to the FPGA ?
what is the best mode to reset the fpga register ?
