NVARA1's avatar
NVARA1
8 years ago
what is the procedure to change notepad to default text editor for modelsim? plz specify each step explicitly.
  • SAR's avatar
    SAR
    Modelsim->Tools->preferences->By Name->select "main"->select"Editor"
    And follow the images posted above.
  • @NVARA1​ please try the steps below.
    From Modelsim Intel menu go to Tools > Edit Preferences
    Look for Editor
    Click change value and point to the executable of your TextEditor.
  • Hi @SAR​ can you double check the steps you describe, I don't see an option to change Text Editor, but to change the file type.
    This is using Modelsim Intel Edition 10.5b
    Snapshot below.
  • SAR's avatar
    SAR
    Highlight the (.v/.vhd) file by click on it. Then, right mouse button click. Select "Properties" and click on "Change"
    Next, select any software as you like...ModelSim or notepad.
