14 years agowhat is the difference between RTL simulation and gate level simulation..
I don't know the difference between RTL simulation and gate level simulation. when i coded program in VHDL, RTL simulation tool is good working, but when i coded program in block diagram, RT...
14 years agoThank you.
My only concern with using STD_LOGIC_VECTORS was that it would be more complex to do simple mathematical operations such as +1 for counting increments. Since then though I have had a look on that there interweb and discovered that if I use the correct library i should just be able to do it the same way as I do to an integer. thanks for your help, quick and to the point. D
