8 years agoWhat is the best way to generate multiple clocks with minimum jitter and delays?
Hi, I have to generate several clocks on Arria 10 SoC board. The clocks and their applications are as follows: 3GHz clock: for clocking external ADC to sample the incoming data, and receive...
8 years agoI see. I was thinking of taking the output clock through the transceiver pins of the FMC connector. I think I'll have to use the clock on the ADC board for sampling then.
However, the problem of synchronizing the 150MHz and 1.5GHz still remains.
