8 years agoWhat is the best way to generate multiple clocks with minimum jitter and delays?
Hi, I have to generate several clocks on Arria 10 SoC board. The clocks and their applications are as follows: 3GHz clock: for clocking external ADC to sample the incoming data, and receive...
8 years ago --- Quote Start --- while the last one (3GHz) would be used to sample the received analog signal at external high-speed ADC --- Quote End --- Yes, that's my point. Where do you connect the ADC clock input?
