15 years agoWhat is PCML?
Hi, I am confused about the PCML, I think it is a I/O standard like CML(Current Mode Logic), and so I guess PCML means Pseudo Current Mode Logic. But the Glossary in Altera's web sit defi...
15 years ago --- Quote Start --- Hi hdjun, Are you driving a clock-like signal to the delay chip, or a signal that can be spread using a PRBS signal? If so, then you could consider AC-coupling the link, and then it does not matter what the common-mode voltage is, or what the transmitter current capability is. The only thing that will matter is the voltage-swing at the transmitter and receiver. --- Quote End --- Hi, Dave Thank you for your response and your good suggestion! Because I want to use the voltage level (the more stable part of the high-speed signal) and hope that the voltage level could not drop or rise when the transimitter drive continuantly logic "1" or logic "0" at some time. So I would prefer the DC-couple termination in my design. Consequently, the sink current capability seems important to instructing my design. Altera's documents say that 1.5-V PCML can be compatible with 1.5-V PCML through DC or AC coupled termination while only compatible with 2.5-V or higher PCML through AC coupled termination. I think maybe it is ok with 1.5-V CML DC-coupled termination, but I am not sure. Maybe, we should choose the AC-coupled termination for safer and less risk, haha.:cool:
