skuma161
7 years agowhat is meant by reset bridge
sstrell
7 years agoAssuming you are referring to Platform Designer, the reset bridge component allows you to distribute a reset signal from outside a system to all the components inside the system. It has a reset sink interface on one side and a reset source interface on the other. The sink is typically exported to connect to an outside reset signal, while the source is connected to the reset inputs of all the other components in the system. You can learn more about the reset bridge and other basic components here:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-platform-designer.pdf
#iwork4intel
