13 years agoWhat is Altera postion about USB Blaster Clones?
Hello, I am developing an Cyclone IV development kit and want to embed an USB Blaster compatible circuit (not the same hardware). Is there any license requirement or legal problem regarding th...
13 years ago --- Quote Start --- We are implementinng a very minimalist solution (microcontroller based) to reduce cost. Our board is targeting people that never used FPGA so usually a low cost board helps a lot. --- Quote End --- So long as you do not want to be compatible with Quartus,, i.e., want your hardware to appear as a USB-Blaster, you can use the microcontroller to program the FPGA using standard methods. For example, http://www.ovro.caltech.edu/~dwh/carma_board/fpga_configuration.pdf The minimalist approach is probably an FTDI FT232H in MPSSE mode, i.e., a chip that costs ~$2.50. Cheers, Dave
