11 years agoWhat does Altera call their version of Xilinx DNA?
Hi, Xilinx chips have a feature that xilinx calls "chip DNA" where there is an array of laser fuses on each chip and Xilinx blows out a unique fuse pattern on each die before it is shipped. Th...
11 years ago --- Quote Start --- I Googled "altera unique serial number" (yeah, I know, you are kicking yourself for not doing that ...) --- Quote End --- Actually I did... with that search google gave me (and still gives me) a bunch of links for illegal quartus warez serial number cracks.... and a few links related to MAC addresses for people running linux on NIOS. --- Quote Start --- You are looking for the "Altera Unique Chip ID IP Core User Guide". --- Quote End --- Thanks. I have to say it is very unhelpful that they plaster the acronym "IP" all over this. It's a hardware feature I'm looking for, not IP. --- Quote Start --- I started Quartus, made the IP Catalog visible, --- Quote End --- An IP catalog is (and continues to be) the very last place I would look for documentation about a hardware feature. If Altera is sticking documentation about their device's hardware properties under something titled "IP", then they are just completely bonkers. --- Quote Start --- I suspect that this IP core is not supported with the Cyclone III. --- Quote End --- Thanks, but I don't really care about IP cores, I want to know if the device physically has die-unique fuses blown out at the foundry. It's a pretty clear-cut answer; they have to put it through a whole extra far-back-end step at UMC. Either they did or didn't do that. --- Quote Start --- A work-around would be to create a read-only register. The downside to that solution is that you need to re-synthesize for each device. --- Quote End --- As explained earlier, that is not an option here. The product on which the Cyclone is deployed has no nonvolatile storage of any kind.
