15 years agowhat buffer element to achieve delayed output...not LCELL usage
Hi, I need a delayed outputs I don't want to use LCELL as suggested by Forum members as it is bad practice. Below is a code which i used in Xilinx for same operation. Eg : (* LOCK_P...
14 years ago --- Quote Start --- Hi, I need a delayed outputs I don't want to use LCELL as suggested by Forum members as it is bad practice. --- Quote End --- Perhaps you should first explain why you think you need a delayed output since, in many cases, that's not a good practice either regardless of the implementation. Kevin Jennings
