14 years agoWhat Altera Dev board should I get?
I am looking to implement an embedded system which is going to control and orchestrate a whole bunch of fast switches on/off etc. Main requirements are that I need to talk to the board via seri...
14 years agoOk I see, for some reason I thought the Avalon bus was a separate Altera IC. But it is just their embedded bus on the fpga. I will read the Avalon document.
I'm an EE with some experience coding on TI microcontrollers. Our current designs use microcontrollers with FPGAs as co-processing/routing. But for this design I would like to have a embedded SOC on fpga. What do you think are the pros/cons of using NIOS II vs. a separate microcontroller, besides space?
