14 years agoWeb Server: The code auto-negotiation fails with a router?
Question# 1: I am implementing Web server on my own design. The code auto-negotiate with ethernet hub and switch, but not with a router. What could be possibly wrong with my code? Cross ...
14 years agoOn 1) does it say autonegotiation fail in the terminal? Do the LEDs on the router show that something is connected when you plug in the board? Maybe you could dig a bit deeper into the datasheet and check the contents of the PHY MDIO registers and find out if anything is strange there. You shouldn't need a cross-over cable as the PHY is capable of MDI-X.
On 2) what kind of messages do you have in the terminal? Does the autonegotiation succeed? What does it say about the DHCP transaction? Are you using both precompiled hardware and software given with the kit?
